Loading D&B Data Using Sample Scripts
This topic provides some guidance about how to use sample scripts for:
Caution: Before running scripts, check
them against the D&B data layout documentation and against the
S_DNB_UPDATE table columns. Then, modify the scripts as required.
For information about the S_DNB_UPDATE table columns, see the applicable Siebel Data Model Reference on My
Oracle Support.
