About Modifying LOVs in RR Environments
Since you can modify lists of values (LOVs) in both DR and RR environments, a potential conflict arises when you have changed LOVs in either DR or RR and you want to perform a full or incremental migration. For example:
If the same record exists in both DR and RR and the record is modified in DR but not in RR, then which record takes priority?
If the same record exists in both DR and RR and the record is modified in RR but not in DR, then which record takes priority?
If the same record exists in both DR and RR and the record is modified in both DR and RR, then which record takes priority?
Seed Migration Priority
To resolve any conflicts that might arise when migrating from a DR to an RR environment, a system preference called Seed Migration Priority has been introduced. You can set Seed Migration Priority in the RR environment to one of the following values:
Source. If Seed Migration Priority is set to Source, then precedence is given to the seed data in the DR environment.
Target. If Seed Migration Priority is set to Target, then precedence is given to the seed data in the RR environment.
Example of Conflict Resolution for Full Migration
The following table shows how conflicts are handled during full migration from a DR to an RR environment.
| If you do the following before migration: | Conflict | The seed record in RR when Seed Migration Priority
= 'Source' |
= 'Target' |
Modify record in DR only |
No |
DR record is imported to RR. |
Modify record in both DR and RR |
Yes |
RR record is retained. |
Modify record in RR only |
Yes |
Example of Conflict Resolution for Incremental Migration
The following table shows how conflicts are handled during incremental migration from a DR to an RR environment.
= 'Source' |
= 'Target' |
No |
Yes |
No |
Example of How Inserts are Handled During Full or Incremental Migration
The following table shows how inserts are handled when migrating from a DR to an RR environment.
= 'Source' |
= 'Target' |
Insert a new record in DR |
No |
Insert a new record in RR |
No |
Insert a new record with the same Name, LIC and Type in both DR and RR |
Yes |
DR record is imported. |
Users must log out of the application and then back in again for any changes to take effect.
About Conflict Resolution
The following points summarize how conflicts are resolved during migrations:
Only conflicting records honor the Seed Migration Priority setting. For non-conflicted records, the regular migration rule (that is, migration of data from source to target) applies.
New records in both (DR and RR) environments are handled as follows:
New records created in DR are always migrated to RR no matter whether the Seed Migration Priority is Source or Target.
New records created in RR are always retained in RR no matter whether the Seed Migration Priority is Source or Target.
If a new record is created with the same name in both DR and RR, then the following behavior applies:
If Seed Migration Priority is Target, then source DR records are skipped and target RR records are retained.
If Seed Migration Priority is Source, then source DR records are imported and target RR records are deleted.
Deleting a seed record is a modification, which follows the same rules that apply for record modification. All deleted records become inactive.
Foreign Key References for Seed Data After Migration
As of Siebel CRM 21.6 Update, foreign key references (for example, from LOVs to Organization) are resolved as follows when migrating seed data from a development (DR) environment to any RR environment (such as Production):
If the target environment has a record with a matching name (for example, Organization Name), then the seed data record will resolve the foreign key to that matching record.
If the target environment has no record with a matching name, then it will not be possible to resolve the foreign key. In such cases, an error is logged indicating that the foreign key could not be resolved and the administrator of the RR environment must manually create a matching record and manually update the seed data record to point to that new record as follows:
Manually create an Organization in the RR environment with the same name as the DR environment.
Manually update the LOV record(s) to refer to the newly created Organization.
