Using Siebel Developer Web Client
You can start a Siebel application from the Siebel Developer Web Client.
To start a Siebel application from the Siebel Developer Web Client for the first time
  1. From the Start menu, select Programs and then select your Siebel application.
  2. Enter SADMIN in the User ID field and the appropriate password in the Password field.
  3. In the Connect to field, select the server database from the drop-down list, and click OK.
    For information about the other databases available in the Connect to drop-down list, see Selecting a Data Source.
