Use batch assignment to assign multiple records of an object in
a single batch. Typically, you want to run batch jobs periodically
when you anticipate the least amount of database activity (such as
daily or weekly after-hours).
Batch assignment runs only in rule group mode. At the time of the
assignment request, you specify one of the rule groups as the Assignment
Key parameter for the AsgnBatch server component job along with the
request. You identify the records for batch assignment using an SQL
WHERE clause. This WHERE clause is usually based on columns in the
base table of the assignment object. For example, an example of a
WHERE clause is:
WHERE OWNER_EMP_ID = NULL
You can use this clause to identify all service requests that are
not as yet assigned to a owner.
You can have a batch assignment task load only a particular group
of rules into memory by specifying the row ID of the rule group in
the Assignment Key parameter when you start the task. If no rule group
is specified for this parameter, then the batch task loads all rules
in the Default Rule Group into memory. If no rule groups have been
defined in the application, then all active rules in the database
load.
Caution: For performance reasons,
do not run dynamic assignment when running batch assignment. If you
run both batch assignment and dynamic assignment in your environment,
then the batch assignment can activate dynamic assignment due to triggers
created in the database required to run dynamic assignment. Before
running batch assignment, deactivate all assignment policies and drop
related triggers to prevent dynamic assignment from processing modified
rules, objects, and candidates. After completing batch assignment,
you can reactivate the assignment policies and re-enable dynamic assignment.
This topic contains the following information:
