Avoiding Duplicate Assignment Criteria Values
It is possible to create duplicate criteria values for an assignment criterion. If both criteria values use scores in this case, then both scores are added to the assignment criterion if the criteria value passes. This result can occur when you create criteria values that use ranges, such as criteria values for the Revenue assignment criterion.
Note: It is recommended that you do not create duplicate criteria
values for the same assignment criterion, even though Assignment Manager
allows this. If both criteria values use scores and you use the Include
inclusion method, then the score added to the passing candidate might
be inconsistent. If you use the Include All or Include All Matching
inclusion method, then both the scores are added to the passing candidate.
