7.0 Flow Usage
If you create a new Workflow Process, then it is strongly recommended that you do not use the 7.0 Flow workflow mode. If you do not define a workflow mode for a Workflow Process in a release that occurs prior to Siebel CRM version 8.1, then Siebel CRM assumes the mode is 7.0 Flow. If you create a new Workflow Process, then make sure you do not set the Workflow Mode property to 7.0 Flow so that Siebel CRM does not assume the mode is 7.0 Flow. Starting with Siebel version 8.1, if you create a new Workflow Process, then the Workflow Mode property is set to Service Flow by default.
