Search Specification Input Argument Fields
The following table describes fields that you can define for an input argument on a search specification on the Search Spec Input Arguments tab of the Multi Value Property Window (MVPW) pane.
| Field | Description |
| Expression Business Component | If you enter Expression in the Type field, then you must enter the name of the business component that evaluates the expression. For example, in the Search Specification field, you can enter the following code: In this example, the expression business component evaluates Order Date so that Siebel CRM uses the following search specification:  |
| Filter Business Component | Enter the name of the business component that provides the group of records that Siebel CRM uses to do the search. |
| Search Specification | The value you enter depends on the value that you select for the Type argument:
 To evaluate this expression, Siebel CRM uses the Expression business component that you define. |
| Type | (Required) Select either Literal or Expression. |
| Comments | Enter a text description of the purpose of the search. |
| Changed | Check mark indicates a changed search specification. |
