Passing Data Through a Process Property to an Error-Workflow Process
Siebel CRM can pass more than just a system defined process property to an error-Workflow Process. It can pass the following information:
        Workflow Process instance. To pass a Workflow Process instance to a process property that resides in an error-Workflow Process, you must redefine these process properties in the error-Workflow Process. You must use the same name and data type in each of these Workflow Processes.
        Property set of a Workflow Process instance. To pass the property set of a Workflow Process instance to an error-Workflow Process, you must define a hierarchy process property in the Workflow Process and in the error-Workflow Process. You must use this hierarchy property to pass the property set.
        The name of a Workflow Process instance. To pass the name of a Workflow Process instance, you must define a process property in this Workflow Process and in the error-Workflow Process. You must configure Siebel CRM to pass the name of the Workflow Process instance through this process property.
To pass data through a process property to an error-Workflow Process
          Define an error exception connector. For more information, see Example of Error Exception Handling.
          Click the stop step, and then define an input argument in the MVPW pane using values from the following table. Field Value Name %1Type Literal Value Error Message (or a valid string)
          In the Workflow Processes list, create a new Workflow Process that references the error-Workflow Process.
