Preparing the Process Simulator for Use with a Script
You can use the Process Simulator with a Workflow Process that references a business
            service or a business component that contains a script. If this script includes a
            breakpoint, and if the Arguments field in the debug configuration contains
                /h, then the simulator might not perform as expected. A
                breakpoint is a marker on a line of Basic code that instructs Basic to pause
            at that line so that the Siebel Debugger can examine the program state. The
                /h argument instructs the Siebel Debugger to open the Watch
            window.
To prepare the simulator for use with a script
                    Remove every breakpoint from the script that resides on a business service or a business component that the Workflow Process references.
                    Remove the /hargument from the debug configuration:-
                            Click the View menu, then select the Options menu item.
                            Click the Debug tab.
                            Remove the /hargument from the Argument field.
 For more information, see Using Siebel Tools.
