Running a Workflow Process to Avoid a Response Data Insert
You can run a Workflow Process to avoid response data inserts.
To run a Workflow Process to avoid a response data insert
- Do one of the following: - Leave the In/Out property of the process property set to In/Out until immediately upstream from the end of the Workflow Process.
- Immediately upstream from the end of the Workflow Process, call another step that nulls out values that Siebel CRM stores in the process properties. - If you use this configuration, then Siebel CRM does not send a reply to the Server Request Processor and it does not insert a record in the S_SRM_DATA table.
- Review the process properties, and then set the In/Out property to NONE.
