Stopping a Workflow Process Instance with a Script
You can use the _StopInstance method in a script to stop a Workflow Process
      instance. For example, assume you must stop an instance of an interactive Workflow Process
      that the user paused or that is suspended on a wait step. In this situation, Siebel CRM cannot
      determine the Process Instance Id from the script. You must know the Process Instance Id in
      order to use the _StopInstance method.
To stop a Workflow Process instance with a script
- Call the - _StopInstancemethod on the Workflow Process Manager business service.- The following example hard codes the Process Instance Id: - var bs_WF = TheApplication().GetService("Workflow Process Manager"); var ps_inputs = TheApplication().NewPropertySet(); var ps_outputs = TheApplication().NewPropertySet(); ps_inputs.SetProperty("ProcessInstanceId", "1-IIT"); bs_WF.InvokeMethod("_StopInstance" , ps_inputs, ps_outputs);
