Using Compound Expressions and Substitutions in a Search Specification
You can use compound expressions and substitutions in a search expression. For example, consider the following generic format:
"([Field1] > '" + [&Process Property Name] + "') OR ([Field2] IS NULL) OR ([Field3]
IS NULL)" Siebel CRM translates this format to the following value:
([Field1] > 'value') OR ([Field2] IS NULL) OR ([Field3] IS NULL) An expression can include a literal representation of a business component field. For example:
"([Open] > '" + [&dFromDate] + "') OR ([Open] IS NULL)"
"([Open] > '" + [&dFromDate] + "') AND ([Status] IS NULL)" where dFromDate is a custom process property
For more information about using a process property as a substitution variable, see Referencing a Process Property.
