Using Expressions in a Multilingual Environment
In a multilingual environment, it is important for workflows to be language agnostic. As an
      example, if we have a workflow decision step checking for the Account Status being
        Active, but that workflow is in a French environment, the value will be
        Actif, so comparing to the literal value would incorrectly return
      false.
For this reason, expressions involving comparison to MLOV-enabled values should leverage the Language Independent Code (LIC), which would be the same across all languages. This can be done using the built-in LookupValue expression as shown in the following examples.
Decision Step Example
Assume a decision step compares Account Status to Active. The Account Status drop-down list bounds the Account Status field. You can set the Compare To property to Expression and set the Expression property to the following code: [Account Status] = LookupValue ("ACCOUNT_STATUS", "Active")Business Service Step Example
To send an email to an expense approver, assume a business service step calls the Outbound
        Communications Manager. The Comm Recipient Group drop-down list bounds the Recipient Group
        argument. You can set the Type property to Expression and set the Value
LookupValue ("COMM_RECIP_SRC", "Comm Employee")For more information about globalization, see Siebel Global Deployment Guide. For more information about defining Siebel Workflow to use MLOV capable fields, see Configuring Siebel Business Applications.
