Business Component Method Technique
The standard UI requires the user to click a button or to choose a menu item to call a section of business logic. This business logic typically calls a business component method and is not readily available as a business service method. The problem with this kind of user experience is that the user must possess knowledge about the following:
  • The user must click a button to run the logic
  • The user must understand the result of clicking the button
  • The user must understand the sequence to use to click multiple buttons
To avoid this complexity, the task provides the following capabilities:
  • Display unambiguous choices in the Siebel client
  • Describe the result of clicking a button
  • Provide backward navigation
  • Enforce the sequence to use to click multiple buttons
You can provide the user with multiple choices in a task, one choice at a time:
  1. The user makes a choice, and then clicks Next on the task playbar applet.
  2. The task calls the business logic and in the correct order.
  3. If an exception occurs, then the task displays an error dialog.
  4. If an exception does not occur, then the task can display the next view.
This following procedure shows how to use the business component method technique.
To use the business component method technique
  1. If an adapter business service does not exist, then create one with the values shown in the following table.
    Property Value
    Class
    CSSBCAdapterSvc
  2. Make sure the value of the Business Component user property specifies the business component whose method or methods it is adapting.
  3. Define a method with the same name as the business component method that Siebel CRM must call from the task.
  4. Call the business component method from a business service step in the task.
    This business service step must reside downstream of a task view step so that the Next step flows to the business service step and calls the business component method.
    If you enable backward navigation to the selector view, and if this view displays an option that logically negates the underlying business logic that Siebel CRM performs, then you might need to adjust the flow of your business process so that it is compatible with backward navigation and the business logic.
Example of the Business Component Method Technique
The predefined Field Activity Invoicing task displays an option to automatically create an Invoice. The user clicks AutoInvoice in the Invoice applet to create this invoice in the standard UI. The predefined task calls an adapter business service method after the selector view. This task eliminates the requirement to use the AutoInvoice button in the Invoice applet.
