Guidelines for Reusing Views and Applets
To enforce the simpler layout requirements of a task, it is recommended that you create a new applet and view or modify a predefined view and applet. You can use the CSSSWEFrame template to avoid performance problems that might occur with specialized code when you create a new applet.
