Using a Radio Button with a List of Values
You can create a new set of radio buttons in the following situations:
  • According to a new List of Values (LOV). In this situation, the Pick List Wizard allows you to create the LOV picklist.
  • According to an existing LOV. In this situation, the LOV is already defined, so you can reuse it.
Creating a radio button group requires a LOV that Siebel CRM can use to get the choices it displays. To render a radio button group in the Siebel client, the LOV that the radio button group references must exist in the run-time environment. If you deploy the Siebel application for testing or production, then make sure you deploy the LOV to the target environment.
It is recommended that you do not use a hierarchical LOV with a radio button.
For more information, see Configuring Siebel Business Applications.
