Running EIM Data Migration
This topic describes how to run the EIM jobs for implementing the O2C PIP.
Data Migration Sequence
Execute the entities in the following table in sequence to maintain the data integrity. This table includes the pre-and post EIM activities, which must be carried out manually.
| S.No | Main Entities | Task Type |
1 |
Organization |
Manual |
2 |
Inventory Location |
Manual |
4 |
Products |
EIM |
5 |
Post EIM Product Release |
Manual |
5 |
Pricelist |
EIM |
6 |
Customers |
EIM |
7 |
Assets |
EIM |
Before you begin the EIM import, note the following points:
Make sure that the Siebel Server is running.
Make sure that the Siebel EIM component is online and is running properly. (Navigate to the Administration - Server Configuration or Administration - Server Management screen.)
To avoid data loss, do not restart the Siebel Server while the EIM job is running.
After you have completed the data load for one country, make backup copies of the EIM log files, for status verification. These log files are located in the
siebsrvr/logsdirectory.
Checking EIM Component Availability
Use the following procedure to check EIM component availability.
To check EIM component availability
Navigate to the Administration - Server Management screen, Servers, and then the Component Groups view. Make sure that the component group Enterprise Application Integration is active and online.
Make sure that the Enterprise Integration Manager component within the Workflow Management component group is also active and online.
Navigate to the Administration - Server Configuration screen, Enterprise, Component Groups, and then the Components Group Assignments view.
Make sure that the Enterprise Application Integration Component Group is enabled.
Setting Up Organizations
Use the following procedure to set up organizations.
Navigate to the Administration - Group screen, then the Organizations view.
Create the required organizations.
Setting Up Inventory Locations
Use the following procedure to set up inventory locations.
To set up inventory locations
Navigate to the Administration - Data screen, then the Inventory Locations view.
Create inventory locations.
Note: Make sure that the inventory location is associated with the correct location.
