Caution About Using Specialized Classes
A specialized business component class is a type of class that Siebel CRM derives from a generalized business component class. It is recommended that you use a specialized business component class only if necessary. It is recommended that you do not use a specialized business component class with a typical business component. These specialized classes often use functionality that references other objects, such as fields, other business components, or other classes. You must not configure Siebel CRM in such a way that it modifies the values that these objects contain.
You must not modify the Class property of a predefined business component. If you copy a predefined business component, then you must not modify the Class property of the copy.
Oracle only supports methods that Siebel Object Interfaces Reference describes for use in scripting. Modifying method logic before or after Siebel CRM calls this method can cause unpredictable behavior.
For more information, see Siebel Developer's Reference.
