Defining Read-Only Behavior for a Business Component
In this example, if an account record includes a competitor, then the user must not choose any competitors for the account. If the Type field includes a value of Competitor, then Siebel CRM makes the Competitor field in the account record read-only. For more information, see How Siebel CRM Defines Read-Only Behavior for a Business Component Field.
To define read-only behavior for a business component
  1. In the Object Explorer, click Business Component.
  2. In the Business Components list, locate the Account business component.
  3. In the Object Explorer, expand the Business Component tree, and then click Field.
  4. In the Fields list, create a field using values from the following table.
    Property Value
    Name
    Competitor Calculation
    You can use any name.
    Calculated
    TRUE
    Calculated Value
    IIf([Type] = "Competitor", "Y", "N")
  5. In the Object Explorer, click Business Component User Prop.
  6. In the Business Component User Props list, add a new record using values from the following table.
    Property Value
    Name
    Field Read Only Field: Competitor
    Value
    When you create a business component or field, make sure the values in the Name and Value properties use the correct capitalization, spelling, and empty spaces. Make sure that quotation marks are not present.
  7. Compile and test your modifications.
    For more information, see Using Siebel Tools.
