Index Strategy Variable of the Case Insensitivity Wizard
The index strategy is a variable that determines how the Case Insensitivity Wizard defines indexes for the CIAI column.
The following table describes the index strategies you can use with the method variable set to Database. The wizard sets the Default Insensitivity property to DB Case & Accent no matter which index strategy you use.
Index Strategy Work That the Case Insensitivity Wizard Performs
None
Defines no new CIAI columns or indexes.
Single
Defines a new CIAI column and defines a single CIAI index on it.
For every index that includes the base column, the wizard does not create another index that references the CIAI column.
Copy All
Defines a new CIAI column and a CIAI index for the column.
For every index that includes the base column, the wizard defines a copy of that index. The copy references the CIAI column instead of the base column.
