Multi-Value Group, Multi-Value Link, and Multi-Value Group Applet
A multi-value group is a set of child records that Siebel CRM associates with a parent record. A multi-value link is an object that allows you to create a multi-value group. A multi-value group applet is a dialog box that displays the records that constitute a multi-value group. If the user opens the applet from a parent record in a list or form applet, then Siebel CRM uses a multi-value link to build, and then display a multi-value group in the multi-value group applet. For more information, see the following topics:
