Options to Drill Down to Another View
A drilldown is a type of field that allows the user to navigate from a field to another view that displays more information about the chosen record. Siebel CRM displays a drilldown primarily in a list applet. The drilldown object is a child object of an applet. A drilldown can be static or dynamic.
Consider the following drilldown behavior:
  • If the parent applet of a view includes a search specification, and if the user drills down on a field, then Siebel CRM applies this search specification to the destination view. For more information, see Options to Filter Data That Siebel CRM Displays in an Applet.
  • If the target view of a drilldown includes a visibility type that is different from the original view, and if the user drills down on a field, then Siebel CRM navigates the user to the first record of the destination view and not to the drilldown record.
Siebel CRM does not support drilldown on a multi-value group applet, pick applet, or association applet.
