Using Web Templates to Display Menus and Buttons
If the user clicks a menu that is defined as button or link in a Siebel web template, then the Siebel Web Engine uses the <div od-type="menu"> tag to activate a list of menu items. The <div od-type="menu"> tag displays menus in the following ways:
  • Application container page for an application menu
  • Applet for an applet menu
Siebel CRM displays an applet menu as an icon button, typically placed before other buttons, such as Edit and Delete. In the Siebel client, it uses the configuration in the Siebel runtime repository to create a set of menu items for an applet. The tag must be defined in an applet web template for applet menus.
