Using a Default Icon in an Icon Map
If you use icons to represent values in a field, then the Siebel Web Engine displays the image that the bitmap references if the field value matches one of the icons you define. If the field value does not match any of the icons you define, then the Siebel Web Engine uses text to display the actual field value.
You can create an icon named Default in an icon map. If the field value does not match any of the icons, then Siebel CRM uses the Default icon to represent values in the field. This feature is useful to create an icon that Siebel CRM uses if a field might contain different values, such as URLs.
To use a default icon in an icon map
Create or locate an icon map that contains only one icon, named Default.
For more information, see Using Icons to Represent Values in a Field.
Define the control or list column using values from the following table.
Property Description HTML Type
Set to URL.
HTML Icon Map
Set to an icon map that contains only one icon, named Default.
