The following table describes the methods that Siebel Open UI uses
with the ControlBuilder class.
Method |
Description |
Pick |
You can use the following properties
of the configuration object:
target. Specifies the DOM element as
a jQuery object.
click. Attaches a callback method.
scope. Specifies the scope.
control. Sent as an argument to the callback method
that the click property specifies.
className. Modifies the CSS style of
the pick icon.
Mvg |
DatePick |
target. Specifies the input control DOM element as a
jQuery object with a calendar icon and attaches a DatePicker event. Configures Siebel Open UI to
display a dialog box that contains only date options if the user clicks
the calendar icon. DateTimePick does the same
as DatePick except the dialog box allows the user to set the date
and time.
className. Identifies the class.
DateTimePick |
