Enabling Auto Tile Mode at the Application Level
The Auto Tile mode can be enabled at the application level for all qualifying list applets in the Siebel application. The example in this topic describes how to enable Auto Tile mode at the application level.
To enable Auto Tile mode at the application level
Open Siebel Tools.
For more information, see Using Siebel Tools.
In the Object Explorer, click Application.
In the Applications list, query the Name property for the application that you must modify.
For example, Siebel Universal Agent.
In the Object Explorer, expand the Application tree, and then click Application User Prop.
In the Application User Properties list, add the following application user properties.
Name Value EnableAutoTile
TRUE
- Compile your modifications.
