Using Notifications with Operations That Call Methods
It is recommended that you do not use some notifications with an operation that calls a method. For example, if the user paginates to the next page in a set of 10 records, and if you use NotifyInsertWorkSet with the method that calls this pagination, then Siebel Open UI will create 10 separate NotifyInsertWorkSet notifications.
