Showing Presentations for a Call
Complete the following procedure to show presentations for a call in the Siebel Mobile application for Siebel Consumer Goods.
To show presentations for a call
Tap Side Menu and then tap Call Items to display the following:
Call details and activities in the main pane.
Summary call details and a second level navigation list in the side pane.
Navigate to the call that you want using the navigation arrows in the main pane.
All activities for the call appear after the call details in the main pane.
Create an activity of type eMerchandising, and then tap the Start Activity button to record the start date and time for the activity.
Drill down on the eMerchandising link in the Type field.
All the promotional items associated with the call appear in the main pane.
Tap the Generate button to open and uncompress the presentation.
After you uncompress a presentation, all the presentation items appear in the main pane (in thumbnail format).
Tap the Launch button to go to the Player view, where you can start showing the presentation.
Use the Next and Previous arrows to scroll through the presentation.
