Configuring Business Components for Full Synchronization Always
The following procedure shows you how to configure full synchronization always for business components where objects are fully synchronized even if incremental synchronization is enabled for the Siebel Mobile disconnected application. Full synchronization is where a full data and metadata download takes place between Siebel Mobile and the mobile client whenever the mobile client sends a synchronization request to the Siebel Server.
To configure objects for full synchronization
Navigate to the Administration - Siebel Mobile screen, then the Application Administration view.
Select the mobile application from the upper applet.
Query for the Always Full Download - BusComp setting, and then in the Value field select the dynamic business component.
In the following example, Calls is selected in the Value field for the Always Full Download - BusComp setting. This means that full synchronization will always be performed for Calls even if incremental synchronization is enabled for the application.
Name: Always Full Download - BusComp
Value: Calls
You can specify more than one business component as the value for Always Full Download - Buscomp and the list of business components must be separated by |, for example as follows:
Calls|Pharma Professional Call - Mobile|Contact
