Removing a Business Component Filter Setting
The following procedure shows you how to remove a business component filter setting.
To remove a business component filter setting
  1. Navigate to the Administration - Siebel Mobile screen, then the Application Administration view.
  2. Select the appropriate mobile application in the upper applet, and then click the Business Component Filters tab.
  3. Select the filter setting record that you want to remove.
  4. From the Business Component Filters menu, choose Delete Record.
