Setting Up CardDAV Dynamic Mapping for Siebel CRM
Before you can use CardDAV functionality in Siebel applications, you must set up CardDAV dynamic mapping. CardDAV dynamic mapping defines the mapping between Siebel objects and the CardDAV properties. The Siebel CardDAV Sync module synchronizes the defined entities (address book and contact data) accordingly between mobile devices and Siebel CRM applications.
Siebel CardDAV dynamic mapping supports:
  • Google Maps Geocoding API integration (with geocoding response in JSON) to normalize address data.
    Note: Customers are responsible for Google Maps API licensing.
  • Addresses containing non-ASCII characters.
  • Non-US addresses with a specified Province or County.
Before setting up CardDAV dynamic mapping for Siebel CRM deployments, the following requirements apply:
