Example of Using the Insert Method
If you use the Insert method with the example of the integration object instance represented in XML that follows, then a new service request is created with two activities.
<?xml version = "1.0" encoding = "UTF-8"?>
<?Siebel-Property-Set EscapeNames="false"?>
<SiebelMessage MessageId = "1-2R6E" IntObjectName = "Sample Service Request"
MessageType = "Integration Object" IntObjectFormat = "Siebel Hierarchical">
  <ListOfSampleServiceRequest>
<ServiceRequest>
	<Account>Genesys Communications</Account>
	<AccountLocation>San Francisco, CA</AccountLocation>
	<Area>Network</Area>
	<ClosedDate/>
	<CommitTime/>
	<ContactBusinessPhone>4155551100</ContactBusinessPhone>
	<ContactLastName>Kastrup-Larsen</ContactLastName>
	<Description>Setting up Router services<Description>
	<Priority>3-Medium</Priority>
	<SRNumber>1-MYUNIQUEVALUE</SRNumber>
	<ServiceRequestType>External</ServiceRequestType>
	<ListOfAction>
 		 <Action>
    			<BillableFlag>N</BillableFlag>
    			<Description2>test activity1</Description2>
    			<EstWorkTimeRemaining>8</EstWorkTimeRemaining>
    			<Planned/>
    			<PrimaryOwnedBy>SADMIN</PrimaryOwnedBy>
    			<RowStatusOld>N</RowStatusOld>
   			<Status>Unscheduled</Status>
    			<Type>Appointment</Type>
  </Action>
  <Action>
    		<Description2>test activity2</Description2>
   		<Planned/>
  	  </Action>
	 </ListOfAction>
	</ServiceRequest>
	</ListOfSampleServiceRequest>
</SiebelMessage>
For this example to work, you must have the contact, Kastrup-Larsen, in the database. If you try the Insert method against a server database where the contact does not exist, then you will receive the following error:
Picklist validation of field 'Contact Last Name' in integration component 'Service
Request' did not find any matches satisfying the query '[Last Name] = "Kastrup-
Larsen"', and an attempt to create a new record through the picklist failed (SBL-
EAI-04186)
Also, if you try to insert the previous instance a second time, then you will receive the following error message:
IDS_ERR_EAI_SA_INSERT_MATCH_FOUND. Insert operation on integration component
'Service Request' failed because a matching record in business component 'Service
Request' with search specification '[SR Number] = "1-MYUNIQUEVALUE" was found.(SBL-
EAI-04383).
