Insert Method
The Insert method is called when a New Record is committed. The following figure illustrates the property set for the Insert input.
The following is the XML representation of the property set shown in the previous figure:
<?xml version="1.0" encoding="UTF-8" ?>
<?Siebel-Property-Set EscapeNames="true"?>
<PropertySet
Business_spcComponent_spcId="1"
Business_spcComponent_spcName="Contact">
<PropertySet
AccountId="1-6"
Name="Max Adams"
Phone="(398)765-1290"
Location="Troy"
AccessId="" />
</PropertySet>
The following figure illustrates the property set for the Insert output.
Note: The property set for the Insert output does not affect the data in the business
component. The output property set for Insert is used to indicate what fields or records
were changed.
<PropertySet
<PropertySet
AccountId="1-6"
Name="Max Adams"
Location="Troy"
AccessId="146" />
</PropertySet>
