Example of Importing and Exporting Hierarchical LOVs
You can migrate a hierarchical list of values from one Siebel CRM environment to another, as shown in this example.
To migrate a hierarchical list of values
Run an EIM export task using the following .IFB settings:
[Siebel Interface Manager] USER NAME = "SADMIN" PASSWORD = "SADMIN" PROCESS = Export LOV [Export LOV] TYPE = SHELL INCLUDE = "Export LOV_TYPE" INCLUDE = "Export LOV_REPLICATION_LEVEL" INCLUDE = "Export LOVs_Parent" INCLUDE = "Export LOVs_Child" USE INDEX HINTS = TRUE [Export LOV_TYPE] TYPE = EXPORT BATCH = 1 TABLE = EIM_LST_OF_VAL EXPORT MATCHES = (TYPE = 'LOV_TYPE' and \ VAL <> 'LOV_TYPE' and \ VAL <> 'REPLICATION_LEVEL') USE INDEX HINTS = TRUE [Export LOV_REPLICATION_LEVEL] TYPE = EXPORT BATCH = 2 TABLE = EIM_LST_OF_VAL EXPORT MATCHES = (TYPE = 'REPLICATION_LEVEL' and \ VAL <> 'All') USE INDEX HINTS = TRUE [Export LOVs_Parent] TYPE = EXPORT BATCH = 3 TABLE = EIM_LST_OF_VAL EXPORT MATCHES = (TYPE <> 'LOV_TYPE' and \ PAR_ROW_ID IS NULL and \ ROW_ID NOT IN ('0-1EOTJ', '0-1EOTR', \ '0-1EOTT', '0-1EOTX', '0-1EOTZ', \ '0-1EOUB', '0-1EOUF', '0-1EOUH', \ '0-1EOUJ', '0-1EOUL', '0-1EOUN', \ '0-1EOUR', '0-2SRAZ', '0-3EM3U', \ '0-3EM3Y', '0-3EM42', '0-3G4D0', \ '0-3G4D2', '0-3GBNN', '0-3GFJQ', \ '0-3GFJV', '0-3K8OB', '0-3LEF9', \ '0-3LG6Z', '0-3RL6J', '0-3YWL5', \ '0-3YWLD', '0-40X27', '0-6ECJG', \ '04-AZLJB', '04-AZLJD', '04-AZLJF', \ '04-AZLJH', '04-BF0LX', '04-BF0LZ', \ '04-BF0M1', '04-BF0M3', '04-BF0M7', \ '04-BF0M9', '04-BF0MO', '04-BKLND', \ '04-BKLNN', '04-CYI2Z', '04-CYI32', \ '04-CYI34')) USE INDEX HINTS = TRUE [Export LOVs_Child] TYPE = EXPORT BATCH = 4 TABLE = EIM_LST_OF_VAL EXPORT MATCHES = (TYPE <> 'LOV_TYPE' and \ PAR_ROW_ID IS NOT NULL and \ ROW_ID NOT IN ('0-6DCE7', '04-AQ79M', \ '04-AQ79O', '04-AQ79Q')) USE INDEX HINTS = TRUERun the SQL statement that follows to populate the EIM_LST_OF_VAL.PAR_BI and other EIM_LST_OF_VAL.*_BU interface columns.
Note: This SQL statement can be found in<siebel server root>\Admin\eim_export_lookup_bu_name.sql. Locate the SQL for EIM_LST_OF_VAL.update EIM_LST_OF_VAL IT set IT.BITMAP_LIT_BU = (select min(OI.NAME) from S_BU OI where OI.ROW_ID = IT.BITMAP_LIT_BI) , IT.LOV_BU = (select min(OI.NAME) from S_BU OI where OI.ROW_ID = IT.LOV_BI) , IT.LOV_VIS_BU = (select min(OI.NAME) from S_BU OI where OI.ROW_ID = IT.LOV_VIS_BI) , IT.PAR_BU = (select min(OI.NAME) from S_BU OI where OI.ROW_ID = IT.PAR_BI);Make sure the target environment’s EIM_LST_OF_VAL interface table is empty, then move the exported data from the source environment’s EIM_LST_OF_VAL interface table to the target environment’s EIM_LST_OF_VAL interface table.
At the target environment, verify the existence of the three list of values records that follow before proceeding to Step 5.
Type Display Value Replication Level LOV_TYPE
LOV_TYPE
All
LOV_TYPE
REPLICATION_LEVEL
All
REPLICATION_LEVEL
All
All
- If these records do not exist, then create them in the Siebel client by going to the Administration - Application screen, then the LOV Explorer view.
Run the following SQL at the target environment’s database:
UPDATE EIM_LST_OF_VAL A SET A.IF_ROW_BATCH_NUM = 5 WHERE NOT EXISTS (SELECT 'x' FROM EIM_LST_OF_VAL B WHERE B.LOV_TYPE = A.PAR_TYPE AND B.LOV_VAL = A.PAR_VAL AND B.LOV_LANG_ID = A.PAR_LANG_ID AND (B.LOV_SUB_TYPE = A.PAR_SUB_TYPE OR (B.LOV_SUB_TYPE IS NULL AND A.PAR_SUB_TYPE IS NULL)) AND B.LOV_BU = A.PAR_BU AND B.IF_ROW_BATCH_NUM <= 3) AND A.IF_ROW_BATCH_NUM = 4;If the SQL listed in Step 5 has updated zero records, proceed to Step 7 . Otherwise, run the following SQL at the target environment’s database and repeat Step 6 until the SQL has updated zero records:
UPDATE EIM_LST_OF_VAL A SET A.IF_ROW_BATCH_NUM = <see Note A row in the following table> WHERE NOT EXISTS (SELECT 'x' FROM EIM_LST_OF_VAL B WHERE B.LOV_TYPE = A.PAR_TYPE AND B.LOV_VAL = A.PAR_VAL AND B.LOV_LANG_ID = A.PAR_LANG_ID AND (B.LOV_SUB_TYPE = A.PAR_SUB_TYPE OR (B.LOV_SUB_TYPE IS NULL AND A.PAR_SUB_TYPE IS NULL)) AND B.LOV_BU = A.PAR_BU AND B.IF_ROW_BATCH_NUM = <see Note B row in the following table>) AND A.IF_ROW_BATCH_NUM = <see Note C row in the following table>;Note Value A
Next new batch number; that is, 6 for the first time you run, 7 for the second time you run, and so on.
B
Last batch number; that is, 4 for the first time you run, 5 for the second time you run, and so on.
C
Last batch number; that is, 5 for the first time you run, 6 for the second time you run, and so on.
UPDATE EIM_LST_OF_VAL SET IF_ROW_BATCH_NUM = <next new batch number> WHERE LOV_VIS_BU IS NOT NULL;Run an EIM import task at the target environment using the following parameters:
[Siebel Interface Manager] USER NAME = "SADMIN" PASSWORD = "SADMIN" PROCESS = Import LOV [Import LOV] TYPE = IMPORT BATCH = 1-<last batch number as specified in step 7> TABLE = EIM_LST_OF_VAL USE INDEX HINTS = TRUEMigrate the S_LOV_REL rows using the EIM_LOV_REL interface table.
