Actual and Abbreviation Field 4
Use this user property to define the actual field and corresponding abbreviation in the Function Space Diary.
Actual and Abbreviation Field 4 Description
Value
Expected Num;Expected Num Abbr
Parent Object Type
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary and TNT SHM Function Space Diary Total Availability Applet Applets
Usage
The usage is the same as the Actual and Abbreviation Field 1 user property.
