Compiling What-If Aggregate Quotes for Recurring Events
What-If aggregate quotes allow you to create an aggregate quote for one property. This method is typically used when a number of different properties are competing for the same opportunity, and a sales representative or sales manager for a property wants to see whether the value of the opportunity for the property was involved. This information can then be used in competitive bidding to show a customer that a certain property is less expensive than another property. You can compile what-if aggregate quotes for an unlimited number of properties.
This task is a step in Process of Creating Recurring Events.
To compile a what-if aggregate quote for a recurring event
  1. Generate quotes for the subopportunities of the recurring event as described in Generating Quotes for Subopportunities.
  2. Click the Aggregate Quotes view tab, and then click the Aggregate Quote (What If) link.
  3. Click the Aggregate Quote button.
    If a number of different properties are associated with the subopportunities of the recurring event, then a dialog box appears, instructing you to select a property.
  4. Select the required property for the what-if aggregate quote, and click OK.
    The what-if aggregate quote is compiled and appears in the list, as do the related quotes for the property.
