Creating Volume Discounts
Volume discounts are created through the Administration - Pricing screen. For more detailed information about how to create a volume discount, see Siebel Pricing Administration Guide.
This task is a step in Setting Up Volume Discounts.
To create a volume discount
Navigate to the Administration - Pricing screen, then the Volume Discounts view.
In the My Volume Discounts list, create a new record, complete the fields and save the record.
Some of the fields are described in the following table.
Field Comments Name
Enter a name for this volume discount.
Discount Method
Select the discount method from the picklist. The options are Simple and Tiered. For more detailed information about these methods, see Siebel Pricing Administration Guide.
Effective From
The date from which this volume discount will become effective.
Effective To
The date on which this volume discount will become ineffective. If the volume discount will not expire, leave this field blank.
Exchange Date
If you are converting currencies, enter the date for the currency exchange rate. Siebel Hospitality uses the exchange rate on that date to convert currency.
Description
Enter a description of the purpose of the volume discount.
