Generating Quotes for All Opportunity Properties
When you generate quotes for the properties of an opportunity, then by default, Siebel Hospitality only generates quotes for the properties that are selected. However, you can disable this limitation so that quotes are generated for all properties associated with the opportunity, selected or not.
When quotes are generated for the properties of an opportunity, whether quotes are generated for selected properties or for all properties is controlled by the value of the TNT SHM Multiple Dates Selected Records user property. The possible TNT SHM Multiple Dates Selected Records user property values are as follows:
Y (default). Generates quotes only for selected properties.
N. Generates quotes for all associated properties regardless of selection status.
To generate quotes for all properties of an opportunity, whether selected or not, follow this procedure.
This task is a step in Process of Configuring Opportunities and Quotes.
To generate quotes for all opportunity properties
Start Siebel Tools.
Query for the TNT SHM Visual Quote Service business service and search for the TNT SHM Multiple Dates Selected Records user property.
In the business service, change the value of the TNT SHM Multiple Dates Selected Records user property to N.
Compile the SRF file used by your Siebel application.
For more information about generating quotes from opportunities, see Generating Quotes from Opportunities. For more information about changing the values of objects in Siebel Tools, see the chapter on working with objects in Using Siebel Tools.
