Ignore Case Sensitivity
This user property is used to control the case sensitivity for comparing function space strings and the string entered in the Go To field.
Ignore Case Sensitivity Description
Value
Y
Parent Object Type
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary
Usage
