Item Color Fields
This user property is used to specify the field name that is present in the Y-axis business component in the Diary.
Item Color Fields
Description
Value
Compound Inventory Status
Parent Object Type
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet
Usage
This user property specifies the field name that is present in the Y-axis business component in the Diary. The booking color is displayed in the Diary according to the value of this user property.
