Pivot 0 Group by Group Field
If the value of this user property is Y, then the field specified by the Pivot 0 Group Field is used for grouping.
Pivot 0 Group by Group Field Description
Value
Y
Parent Object Type
TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Type Dync - Group By Type
Usage
If the value of this user property is Y, then the field specified by the Pivot 0 Group Field is used for grouping, rather than the Pivot 0 Type 0 values.
