Running the Nightly Hospitality Workflows
Certain workflows for Histories and Futures functionality are designed to be run every night. You can set up Siebel Hospitality to run these workflows automatically through jobs. For more information about the Histories and Futures workflows, see Workflows for Histories and Futures Functionality.
To set up jobs to run the nightly Histories and Futures workflows, follow this procedure.
This task is a step in Process of Setting Up Hospitality Workflows.
To run the nightly Hospitality workflows
  1. Navigate to the Administration - Server Management screen, then the Jobs view.
  2. In the Jobs list, create a new job.
  3. In the Component/Job field, select the component with the Name of Workflow Process Manager.
  4. In the Job Detail Form, complete the fields as shown in the following table.
    Field Value
    Repeating
    Select
    Repeat Unit
    Hours
    Repeat Interval
    24
    Repeat From
    Scheduled Start
  5. In the Job Parameters list, add a component-specific parameter with the value shown in the following table.
    Name Value
    Workflow Process Name
    TNT Nightly Update History Opportunity Workflow
  6. In the Jobs list, with the Workflow Process Manager job selected, click Submit Job.
  7. Verify that the Status field of the Workflow Process Manager job has a value of Active.
  8. Create another job by repeating Steps 1 through 4 of this procedure.
  9. In the Job Parameters list, add a component-specific parameter with the value shown in the following table.
    Name Value
    TNT Nightly 30 60 90 Day Pickup Workflow
  10. Repeat Steps 6 through Step 7 of this procedure for the new job.
