Setting Up Default Government Rates
The following procedure details how to set up the default government sleeping room rates.
To set up default government rates
Navigate to the Property Pricing Admin screen, then the Properties view.
In the Properties list, select the required property.
In the property record, click the link in the Property Name field.
Click the Government Pricing view tab.
In the Government Rate list, create records for each sleeping room type, and complete the fields.
For more information about the fields in the Government Rate list, see Creating Default Sleeping Room Pricing Rules.
Save the record, and click Apply.
Scroll down to the Government Open list, and create a new record for each sleeping room type that defines the dates on which the government rates are available.
The following table describes some of the fields.
Field Comments Sleeping Room
Sleeping room for which available dates are to be defined.
Start Date
The date on which the government rates become available. This date must be the same as the date defined for the sleeping room in the Government Rate list.
Start Day
This field is automatically populated when the Start Date field is completed.
End Date
The date on which the government rates are no longer available. This date must be the same as the date defined for the sleeping room in the Government Rate list. There is some validation on the Start and End Dates as follows:
End Date >= Start Date + 365
This means that a function space pricing rule can only run for one year at the most.
End Day
This field is automatically populated when the End Date field is completed.
Monday - Sunday
Click the check box for each day of the week on which the government rates are available. For example, government rates might not be available on Saturday and Sunday nights. If the pricing rule runs for less than one week, then it will only be possible to edit the fields for the relevant days.
Comments
Comments on the rule.
Save the record, and click Apply. The Government Sleeping Room Pricing list displays the government rates and indicates the dates and days on which these rates apply.
