Sort Specification Field
Use this user property to sort the functions in the Create Agenda Sub Function pop-up applet.
Sort Specification Field | Description |
Value |
Start Time |
Parent Object Type |
TNT SHM Agenda Functions business component |
Usage |
This user property is used to sort the functions in the Opportunities screen, Function Agenda view. This user property is used only if the ViewMode Sort:3 user property is not available. To sort the Function Agenda list on a different field, modify the value of this user property with that field name. |
