TNT SHM Has Function Space Field
Use this user property to define whether or not the function space option is available for the function agenda.
TNT SHM Has Function Space Field Description
Value
N
Parent Object Type
TNT SHM Create Agenda Sub Function VBC business component
Usage
This user property is used in C++ code to manage function space functionality. By default, the value is N, indicating that function space is not available in the Opportunities screen, Function Agenda view. Modify the value to Y if function space is available for the function agenda.
