ViewMode Sort:3
Use this user property to sort the functions in Create Agenda Sub Function pop-up applet.
ViewMode Sort:3 | Description |
Value |
Start |
Parent Object Type |
TNT SHM Function business component |
Usage |
This user property is used to sort the functions in the Opportunities screen Function Agenda view. If you sort the functions on a different field, then modify the value of this user property with that field name. |
