About the Required IBM Fix Packs
After you have installed DB2 Connect, install any relevant IBM Fix Packs. To find out which IBM Fix Pack you need to use, see the Certifications tab on My Oracle Support or the vendor documentation.
Refer to IBM documentation for installing the Fix Pack for your environment.
You can verify the currently installed version of DB2 Connect and the IBM Fix Pack by running the command db2level from the DB2 Command Window. In a UNIX environment, this command is run from a UNIX shell after sourcing the appropriate db2profile. Make a note of the information and compare the Informational tokens from the output against the information in the Certifications tab on My Oracle Support.
In addition to IBM Fix Pack information, the Certifications tab on My Oracle Support contains any other installation requirements.
