DB2 Statistics for Siebel CRM
It is recommended that you apply statistics to Siebel CRM. Update statistics on table spaces that contain EIM interface tables and base tables (including table spaces that contain extension tables and repository tables) when there has been a change of 20 percent or more in the row distribution. It is usually not necessary to update statistics on all of the table spaces, only on those containing tables that have changed.
The RUNSTATS utility and the DSTATS utility are recommended for updating statistics.
