Adding Products to an Inventory
The following procedure shows you how to add a product to an inventory.
To add products to an inventory
  1. Navigate to the Samples screen, then the Inventory Count view.
  2. Create a new inventory count record and complete the following fields on the form that appears:
    1. Sample. Select a product from the Sample list.
    2. Lot #. (Optional) Select a lot number from the Lot # list.
