Changing Which Fields Are Copied to the Product Issue
When the Create Product Issue button is used to create a product issue record from a service request record, data from various fields are copied from the service request record to the new product issue record.
To change which fields are copied when a product issue is created
  • Use the Data Transfer Utilities to edit the LS Medical Create PI from SR data map object.
For information about the Data Transfer Utilities, see Siebel Finance Guide.
